Tutorial: How to create motion envelope model with PTC Creo Parametric from mechanism
Do you need to create motion envelope part - here is the short tutorial for you: How you can create motion envelope model with PTC Creo Parametric from mechanism:
    Create your mechanism (use the mechanism constraints: pin, slot, cylinder, etc.)
    Create necessary Servo motors for your mechanism
    Setup Mechanism analysis >> Run it
    Select Playback button and Play your mechanism or Create a Motion Envelope part
  5. Step 5:
    ... for a Motion Envelope part you can set custom quality level and output format
  6. Step 6:
    Here is the final animation: http://youtu.be/qZCStk9TqV4
