Tutorial: How to make Dodechahedron
Here is another way to make a same thing but with help of sheetmetal features of SW. It used base flange, cut holes and sketched bend features.
First make sketch as you see on pic with 5 side polygon diameter 250mm and with base flange make a sheetmetal plate 1mm thick
First step
Now cut a holes -dia 2 mm on problematic corners - think where is!
Now use sketched bend at angle 63.43 degrees with radii 0.01mm -
Next bending with same parameters
Final bending with same parameters.
Here is flat pattern from sheetmetal
And colored part
