Tutorial how to make engine part 1
draw two circles like shown on the front plane
add two tangent line
add two more circle
draw a line and mirror it
draw a centerline and use trim command
use fillet command like shown
go up side and use trim command
use fillet command again
extrude the sketch in two directions. (5,5 mm for each way, total 11mm)
open a sketch on the body and draw a line. make parallel the line with the shown edge
Step 11:
mirror the line and add this two circle
Step 12:
Intersect the lines and use trim command
Step 13:
use trim command and mirror it
Step 14:
draw two circles and cut the body
Step 15:
draw two circles more and cut the body again. use offset feature
Step 16:
draw a sketch on the body like shown
Step 17:
extrude it 2mm and use mirror command
Step 18:
now use fillet command
Step 19:
your connecting rod is ready to use ( create a folder and save into it, firstly we will generate the V12 engine parts )
Step 20:
from Luis :)
