Tutorial how to make engine part 19
![](https://d2t1xqejof9utc.cloudfront.net/members/avatars/19272/feed.jpg?1336975758)
Carter 4
use move-copy- body command
go on like this
use same command again
open a sketch on blue surface
use section view command..
use convert entities command
use trim command and trim this lines
add a 70mm radiused circle
trim the sketch
extrude it
Step 11:
use move-copy body command
Step 12:
go on like this
Step 13:
copy last part
