Tutorial: How to make engine part 28
CYLINDER HEADS
Prepare yourself a cup of coffee, sit back in your chair and open a sketch on the top plane
draw a rectangle
extrude it by 12 mm
open a sketch on the top plane again
draw a circle
extrude it by 90mm
open a sketch on the top plane and draw shown circles
add these two circles to your sketch
open a sketch on the top plane and draw these two lines. they are for to create planes
use referance geometry--plane command
Step 11:
firstly click on the shown surface
Step 12:
then click on the line
Step 13:
enter 345 degrees
Step 14:
now go to other side and make same things for the new plane
Step 15:
enter 350 degrees at this time
Step 16:
open a sketch on the plane 2
Step 17:
draw shown sketch
Step 18:
use 3D sketch command
next: http://grabcad.com/questions/tutorial-how-to-make-engine-part-29
