Tutorial: How to make engine part 35
CYLINDER HEADS
open a sketch on the shown face
draw shown sketch
extrude it by 24 mm
draw same sketch on the other side
extrude it by 30 mm
use fillet command
use fillet command for shown edges
open full round fillet command
select these faces
finally select this face and confirm that
Step 11:
use full round fillet command on the other side
Step 12:
fillet these edges
Step 13:
continue to use filleting
Step 14:
open a sketch on thee shown face
Step 15:
draw two rectangles
Step 16:
extrude it by 10 mm
Step 17:
open a sketch on the shown surface
Step 18:
draw shown sketch..
Step 19:
cut the body
Step 20:
Step 21:
draw a circle
Step 22:
draw a circle on the other side
Step 23:
extrude it by 10 mm (2)
Step 24:
use fillet command (2)
Step 25:
use fillet command again
Step 26:
open a sketch on the same face and draw two circle
Step 27:
cut the body by 7 mm
Step 28:
Step 29:
draw a circle
Step 30:
Step 31:
Step 32:
Step 33:
Step 34:
Step 35:
Step 36:
Step 37:
draw a circle
Step 38:
Step 39:
Step 40:
Step 41:
Step 42:
Step 43:
next: http://grabcad.com/questions/tutorial-how-to-make-engine-part-36
