Tutorial: How to use Creo Simulate Lite in PTC Creo and show design intent
Here is the short tutorial for you
Create your model (200 surfaces max.)
Select Application >> Simulate
System open the Process Guide window for you - click Next>> (button)
In Process Guide window select assign (do you need to assign Material for your model)
Then select Next>> (button) -
Now do you need to set the constraints for model - select constraints In Process Guide window
You can set Displacement constraint or ... -
... Planar constraint or ..
... Pin constraint or ..
... Ball constraint
for continue select Next>> (button) -
Now set Loads
Note: in Creo Simulate Lite you can set Force Load - it is not possible set Momentsfor continue select Next>> (button)
Click this link to RUN an analysis
Step 11:
System open the Diagnostic window for you. Select Next>> (button)
Step 12:
View results of the analysis - click results link
Step 13:
System open the Creo Simulate Results window for you (you can save this analysis, print, etc.)
