Tutorial - Making iPhone 4s in SolidWorks Part 2?
Here is the second part.
Front face >> Sketch.
Draw a circle of 4.8mm dia.
Extrude cut by 1mm at draft of 50º.
Convert the edge.
Extrude it by 0.25 at 50º draft.
Front face >> Sketch. Hide the previous extrusion.
Draw a circle of 2mm dia.
Split line and select the inner face.
Hide the extrusion body.
Step 11:
Dome the inner surface by 0.40mm.
Step 12:
Top face >> Sketch.
Step 13:
Draw a slot.
Step 14:
Extrude cut it by 0.50mm.
Step 15:
Inner face >> Sketch.
Step 16:
Offset the edge by 0.25mm.
Step 17:
Extrude it by 1.10mm without merging result.
Step 18:
Chamfer the edge by 0.20mm at 45º.
Step 19:
Left face >> Sketch.
Step 20:
Draw a rectangle and fillet its's corners.
Step 21:
Draw another circle.
Step 22:
Draw 2nd circle.
Step 23:
Extrude cut them by 0.50mm.
Step 24:
Step 25:
Draw a slot.
Step 26:
Draw two circles.
Step 27:
Extrude them by 1.10mm.
Step 28:
Chamfer the edge by 0.2mm at 45º.
Step 29:
Circular face >> Sketch.
Step 30:
Draw this sketch.
Step 31:
On lower circle draw this sketch using slot.
Step 32:
Extrude cut by 0.2mm.
Step 33:
Here is third part.
http://grabcad.com/questions/tutorial-making-iphone-4s-in-solidworks-part-3
