Tutorial - Making iPhone 4s in SolidWorks Part 3?
Here is third part.
Top face >> Sketch.
Draw two circles.
Extrude cut by 15mm.
Chamfer the edges by 0.275mm at 45º.
Top face >> Sketch.
Offset the circular edge by 0.13mm and 0.26mm.
Split line and select the face. Click OK.
Back face >> Sketch.
Draw a circle and offset it.
Split line and select the back face. Click OK.
Step 11:
Select the previous sketch and then Extruded cut.
Step 12:
Extrude cut by 0.25mm with inner contour.
Step 13:
Inner surface >> Sketch.
Step 14:
Draw a circle.
Step 15:
Extrude cut by 1mm.
Step 16:
Inner face >> Sketch.
Step 17:
Draw a circle.
Step 18:
Extrude cut by 0.50mm.
Step 19:
Inner face Sketch.
Step 20:
Offset the inner edge by 0.250mm.
Step 21:
Split line and select the inner face. Click OK.
Step 22:
Dome the internal surface by 0.5mm.
Step 23:
Select this face >> Sketch.
Step 24:
Select this edge and Convert entities.
Step 25:
Extrude it up to this surface. Uncheck Merge result.
Step 26:
Step 27:
Draw two concentric circles.
Step 28:
Here is fourth part. http://grabcad.com/questions/tutorial-making-iphone-4s-in-solidworks-part-4
