Tutorial - Modeling a PAN Head with taper neck Rivet?
Here is the tutorial.
    Top plane>>Sketch.
    Draw a circle of 16mm dia.
    Reference geometry>>plane.
    Offset top plane at 7mm.
  5. Step 5:
    Plane1>>sketch.
  6. Step 6:
    Draw a circle of 10mm dia.
  7. Step 7:
    Select lofted boss.
  8. Step 8:
    Select both sketch and adjust the connectors.
  9. Step 9:
    Select the bottom face and then plane.
  10. Step 10:
    Offset at 5mm.
  11. Step 11:
    Plane2>>sketch.
  12. Step 12:
    Convert the upper edge.
  13. Step 13:
    Extrude it with draft enabled at 15º outwards.
  14. Step 14:
    Plane2>>sketch.
  15. Step 15:
    Convert the edge.
  16. Step 16:
    Extrude it by 20mm.
  17. Step 17:
    And we have the part.
