Tutorial - Modeling Bolt in Creo Elements aka Pro/E?
Here is the tutorial.
Sketch >> Top plane.
Click Pallete tool.
Choose Hexagon.
Drag it to workspace and adjust it to origin.
Delete the dimension of the side and dimension the circle.
Extrude it.
Draw a circle.
Extrude it.
Edge chamfer tool.
Step 11:
Chamfer the circular edge.
Step 12:
Insert >> Helical sweep >> Cut.
Step 13:
Now press middle click OK.
Step 14:
When we have to select plane, select Front plane.
Step 15:
Draw a center line along the vertical axis.
Step 16:
Draw a line.
Step 17:
Exit the sketch and input the pitch value.
Step 18:
Draw a triangular profile.
Step 19:
Exit the sketch and direction be inside the profile.
Step 20:
Click OK and the feature is generated.
Step 21:
Sketch >> End face of the cut.
Step 22:
Convert the two edges.
Step 23:
Make another line about those lines.
Step 24:
Extrude it with remove material and click OK.
Step 25:
We have the bolt generated.
