Tutorial - Modeling Flower in Creo Element aka Pro/Engineer using Surfacing method 2?
Here is the tutorial.
Sketch >> Front plane.
Draw this spline.
Revolve it about the axis as a surface.
Sketch >> Top plane.
Draw this profile.
Extrude it as a surface.
While selecting the revolved surface goto Edit >> Pattern.
Select Extrude surface as the trimming object direction be inside.
Right click Extrude surface and then hide.
Select the leaf and then Edit >> Geometry pattern.
Step 11:
About axis 6 times.
Step 12:
Select the first surface and then Edit >> Thicken.
Step 13:
Thicken it.
Step 14:
Similarily thicken other surfaces.
Step 15:
Insert >> Revolve.
Step 16:
Click Placement and then define.
Step 17:
Select Front plane.
Step 18:
Draw this profile.
Step 19:
Revolve it.
Step 20:
We have the flower body.
