Tutorial - TopDown Design on SolidEdge ST3
Welcome to my tutorial, for a TopDown design experience...
Download "Starting Assembly" on one of the following links :
https://docs.google.com/open?id=0B_d16xZxXguNaURzdXEyNGtxVTg
or
Tutorial - TopDown Design on SolidEdge ST3 -
Go to the head of Assembly : 01-Tuto_SolidEdge_Asm.asm
You will found two sketches on the head of assembly. -
- Right mouse on the first sketch.
- Select "copy sketch" .... and go to next step -
- Select to destination part for copy (02-Tuto_SolidEdge_Part-1-Cap.par)
- Ensure "Link to file" is check. -
- Repeat the two last steps, to the second sketch,
and this time, link it to : 03-Tuto_SolidEdge_Part-2-Inner.par -
Now, your sketches are linked to the respective parts.
Note : It is possible to link the same sketch to different parts... -
Save all files.
Go to : 02-Tuto_SolidEdge_Part-1-Cap.par
You will find the linked sketch...
Make a revolution of the sketch (360°)
Step 11:
Save part and return to assembly
Step 12:
- Go to : 03-Tuto_SolidEdge_Part-2-Inner.par
Step 13:
Step 14:
Save part and return to assembly.
You will see this on your screen -
Step 15:
Now, try to modify : SKETCH_1_CAP, by change the external radius dimension (15 mm > 30mm).
In our case, sketches have been constrained for this... you will see that the inner have follow the cap modifications.
