Tutorial - Using SimulationXpress in SolidWorks for analyzing a rod?
Here is the Tutorial.
    Start SolidWorks in Part mode.
    Right plane>>Sketch and make a circle of dia 20mm at origin.
    Extrude it by 200mm.
    Tools>>SimulationXpress.
  5. Step 5:
    Click next.
  6. Step 6:
    Select the face of the rod on right plane as the fixture.
  7. Step 7:
    Click Next and the screen shows for force.
  8. Step 8:
    Now select the Selected direction option and select the right face of the rod.
  9. Step 9:
    Now Select the Top Plane and Enter Force value of 1000N i.e. 1KN and check the reverse direction.
  10. Step 10:
    Click OK and Click Choose material and select alloy steel and then Apply, OK.
  11. Step 11:
    Click Next and then run Simulation.
  12. Step 12:
    Now Select the Show Von-mises Stress for stress distribution.
  13. Step 13:
    Select Show Displacement to see the deflection.
