Tutorial - Analyzing the rod for von-mises stress using Mechanica in Creo Elements/Pro?
Here is the tutorial.
Start Creo Elements/Pro in Part mode.
Sketch>>Top Plane and draw a circle of 20mm diameter.
Extrude it by 200mm.
Applications>>Mechanica.
Click OK with default settings.
Insert>>Displacement Constraints.
Select front face and click OK. This will fix all the DOFs of the front face.
Insert>>Force/Moment Load.
Select the other face of the rod. And Enter an value of 10000 in X at Force and click OK.
Properties>>material.
Step 11:
Select Steel and Click >>> button.
Step 12:
Properties>>material assignment.
Step 13:
Keep default settings and click OK.
Step 14:
Analysis>>Mechanica Analysis/Studies.
Step 15:
Click File Menu and then New Static.
Step 16:
Keep the default setting for now and click OK.
Step 17:
Click the green flag to run the analysis. OK.
Step 18:
Click Analysis menu and then Results.
Step 19:
Click this icon.
Step 20:
Select the analysis1 file just created and Click Open. A dialogue window will appear click OK and Show.
Step 21:
The von-mises stress distribution is shown.
Step 22:
Click that icon again and under display options check deformed and click OK and Show.
Step 23:
Now we can see the deformed and undeformed state of the rod under load.
