What simulation tools can you use to test the durability of a part in SOLIDWORKS? How to interpret the data provided by these tools?
SOLIDWORKS offers several simulation tools to test part durability:
A. Static Stress Analysis:
a. Tool: SOLIDWORKS Simulation
b. Purpose: Analyzes stress, strain, and deformation under static loads
c. Interpretation: Look for areas of high stress concentration (red zones in color plots). Compare maximum stress to material yield strength.
B. Fatigue Analysis:
b. Purpose: Predicts part life under cyclic loading
c. Interpretation: Check cycles to failure and damage percentage. Areas in red indicate potential failure points.
C. Non-Linear Analysis:
a. Tool: SOLIDWORKS Simulation Premium
b. Purpose: Analyzes parts under large deformations or with non-linear materials
c. Interpretation: Examine stress-strain curves and deformation plots to assess material behavior beyond elastic limits.
D. Dynamic Analysis:
a. Tool: SOLIDWORKS Motion
b. Purpose: Simulates part behavior under dynamic loads and motion
c. Interpretation: Analyze force and stress plots over time to identify peak loads and critical moments.
E. Thermal Analysis:
b. Purpose: Evaluates heat distribution and thermal stresses
c. Interpretation: Check temperature gradients and resulting thermal stresses. Look for areas exceeding material thermal limits.
F. Drop Test:
b. Purpose: Simulates impact scenarios
c. Interpretation: Examine stress propagation and deformation to assess damage potential.
G. Topology Optimization:
b. Purpose: Optimizes part geometry for strength and weight
c. Interpretation: Use suggested geometry modifications to enhance durability while reducing material.
H. Vibration Analysis:
b. Purpose: Determines natural frequencies and mode shapes
c. Interpretation: Ensure operating frequencies don't match resonant frequencies to avoid fatigue issues.
Interpreting results:
i. Stress plots: Red areas indicate high stress. Compare with material yield strength.
ii. Displacement plots: Check if deformation is within acceptable limits.
iii. Factor of Safety (FOS): Values below 1 indicate potential failure.
iv. Life cycles: In fatigue analysis, indicates expected part lifespan.
v. Convergence: Ensure results stabilize with mesh refinement for accuracy.
vi. Singularities: Be cautious of unrealistically high stresses at sharp corners.
Always validate simulation results with physical testing when possible, especially for critical components.
