Knuckle Joint Assembly
Learn, how to assemble various parts of Knuckle Joint
Step 1: Fork End
Click on 'Import' and import 'Fork End'.
Set it as 'Default'.
Click on 'OK'.
Step 2: Single Eye End
Click on 'Import' and import the 'Single Eye End'.
Apply the constraints.
Click on 'OK'.
Step 3: Pin
Click on 'Import' and import the 'Pin'.
Click on 'OK'.
Step 4: Collar
Click on 'Import' and import the 'Collar'.
Click on 'OK'.
Step 5: Taper Pin
Click on 'Import' and import the 'Taper Pin'.
Click on 'OK'.
Step 6: Final Assembly- Knuckle Joint
