Pin- Knuckle Joint Part 4
Learn, how to draft Pin, a part of Knuckle Joint, by using Creo Parametric.
  1. Step 1: Sketch-1
    Select the top plane and click on 'Sketch'.
    Select 'Center Line' and draw a vertical center line.
    Using the various sketching tool draw the sketch and give proper dimensions as shown in the figure below.
    Click on 'OK'.
  2. Step 2: Revolve-1
    Click on 'Revolve and select the center line.
    Set degree of revolution as 360 degree.
    Click on 'OK'.
  3. Step 3: New Plane-1
    Select the top plane and click on 'Plane'.
    Create a new plane at a distance of 30mm.
    Click on 'OK'.
  4. Step 4: Sketch-2
    Select the previously created plane and click on 'Sketch'.
    Select 'Circle' and draw a circle of 6mm daimeter.
    Click on 'OK'.
  5. Step 5: Remove Material-1
    Click on 'Extrude'.
    Extrude the sketch by 60mm, select 'Remove Material' and enter taper value as 0.018mm.
    Click on 'OK'.
  6. Step 6: Final Part- Pin
