Solidworks Miter Flange | Calculate Blank Size in Solidworks | Export Solidworks File to AutoCAD DXF | CADable | CADable tutorials
Welcome back to CADable with Engr. Ibrahim Omer! In today's tutorial, we're diving into a crucial feature in SolidWorks sheet metal: the miter flange. No worries if you're new – we'll walk through it step by step with an example.
First up, we'll draw a rectangle and then transform it into a base flange/tab. Remember, miter flanges are a bit different from edge flanges – they need a sketch. We'll sketch four lines and tweak some settings to create a simple sheet metal box.
Once our box is ready, it's time to figure out the blank size. We'll use the 'flatten' command for this. Next step? Exporting the file to machining software for cutting – think laser, wire cut, or EDM. We'll save it in DXF format, ready to go.
Chapters of the tutorial:
Introduction 0:00
Sketching centre rectangle 0:23
Sheetmetal base flange/tab feature 0:40
Creating sketch for miter flange 0:55
Solidworks miter flange feature 1:31
Calculate blank size of the box 2:32
Saving file in DXF format for machining 2:43
Conclusion 3:22
This tutorial is perfect for beginners looking to sharpen their skills. Take your time, hit pause if needed, and don't hesitate to drop your questions in the comments. Remember, practice makes perfect!
Don't forget to subscribe to our channel for more tutorials like this:
https://www.youtube.com/c/CADable
#solidworkssheetmetal #solidworksmiterflange #miterflangesolidworks #blanksizeinsolidworks #CADable #CADabletutorials
