Tutorial - Analysis of Bracket in ANSYS Workbench?
Here is the tutorial.
    Start ANSYS Workbench.
    Double click Static Structural.
    Input Name Bracket.
    Right click Geometry >> Import geometry >> Browse.
  5. Step 5:
    Select the bracket.igs file.
  6. Step 6:
    Right click Model and select update.
  7. Step 7:
    The model is updated and it's OK.
  8. Step 8:
    Double click Setup.
  9. Step 9:
    The Mechanical windows shows up.
  10. Step 10:
    Click Loads >> force.
  11. Step 11:
    Input Magnitude = -1000.
  12. Step 12:
    Select the surface and then click apply for geometry.
  13. Step 13:
    Define the direction to downward.
  14. Step 14:
    Now click Supports >> Fixed Support.
  15. Step 15:
    Hold down CTRL key and select the hole surface. Click apply in details.
  16. Step 16:
    Now we have to define which results we want. Right click Solution >> Insert >> Stress >> von-Mises.
  17. Step 17:
    Add Deformation >> Total also.
  18. Step 18:
    Click Solve to start solution.
  19. Step 19:
    After the solution is completed we have tick marks in Solution.
  20. Step 20:
    Select Equivalent Stress to view the plot.
  21. Step 21:
    Select Total Deformation for deformation plot.
