Tutorial - Analysis of Bracket in Mechanica?
Here is the tutorial.
Applications >> Mechanica.
Click OK.
Properties >> Materials.
Select steel.mtl and click >>>.
Now steel is added to materials in model.
Now we have to assign the material to the model. Since we have one part therefore only one material can be assigned. Properties >> Material Assignment.
Select the part and click OK.
Now a yellow symbol will appear which will indicate that the material is assigned.
Insert >> Displacement Constraint.
Select all holes while holding down CTRL key and click OK.
Step 11:
Now all the holes are fixed.
Step 12:
Click Insert >> Force/Moment load to apply load.
Step 13:
Select the top surface of the bracket and in Z direction input 1000N which ~101Kilograms. Click OK.
Step 14:
Now the force is applied and shown in Yellow colour.
Step 15:
Click Analysis >> Mechanica Analyses/Studies.
Step 16:
Click File >> New static.
Step 17:
Input name Bracket and click OK.
Step 18:
Click Start run.
Step 19:
Click Yes.
Step 20:
Now the study is completed. Click Close.
Step 21:
Click Analysis >> Results.
Step 22:
Click Insert a new definition icon.
Step 23:
Select bracket and click Open.
Step 24:
Keep the default settings and click OK and show.
Step 25:
Now the Stress plot is shown.
Step 26:
Click Insert >> Result window.
Step 27:
Select Bracket and click open.
Step 28:
Change stress to displacement.
Step 29:
Goto display options tab.
Step 30:
Check deformed, show loads & show constraints. Click OK and show.
Step 31:
Now we have the displacement plot in the same window.
Step 32:
Step 33:
Select bracket file and click open.
Step 34:
Change stress to strain.
Step 35:
Under display option tab check deformed and click OK and show.
Step 36:
The strain plot is also added to same window.
Step 37:
We have successfully completed the studies of Bracket in Creo Elements/Pro aka Pro/Engineer Wildfire.
