Tutorial how to make engine part 10
more detailed tutorial -- suite
    use extrude command
    select shown areas
    change the direction with using this button
    use offset option
  5. Step 5:
    change the offset direction and enter shown value
  6. Step 6:
    finally enter this value and confirm that
  7. Step 7:
    body is ready
  8. Step 8:
    open a sketch on this surface
  9. Step 9:
    draw two concentric circles
  10. Step 10:
    use cut extrude command like shown.
  11. Step 11:
    your body should be like this
  12. Step 12:
    now open a sketch on this surface
  13. Step 13:
    draw a concentric circle
  14. Step 14:
    normal to selected plane
  15. Step 15:
    draw a big circle
  16. Step 16:
    now we will use this circle option. please click on it
  17. Step 17:
    firstly click on this circle
  18. Step 18:
    secondly clik on this circle and complate your perimeter circle. If you can not, please try again. you will see it is not too hard
  19. Step 19:
    enter the shown dimension
  20. Step 20:
    draw a centerline
  21. Step 21:
    use trim command
  22. Step 22:
    use mirror command and select shown sketch
  23. Step 23:
    then select the centerline and confirm that
  24. Step 24:
    use trim command again
  25. Step 25:
    draw a centerline .
  26. Step 26:
    use mirror command and select the sketch
  27. Step 27:
    select the centerline that we created just now
  28. Step 28:
    draw one more centerline
  29. Step 29:
    use mirror command again. select the shown lines
  30. Step 30:
    select the shown centerline and confirm that
  31. Step 31:
    now use convert entities command and select the shown edges
  32. Step 32:
    select the other hole edges and confirm that. sketch finished.
  33. Step 33:
    extrude it by 60mm
  34. Step 34:
    use linear pattern command and enter shown values
  35. Step 35:
    open a sketch on the right plane and draw an axis for linear pattern direction
  36. Step 36:
    click on solid bodies and select all bodies
  37. Step 37:
    right click and select combine option
  38. Step 38:
    confirm that
  39. Step 39:
    open a sketc on the shown surface
  40. Step 40:
    draw three circles
  41. Step 41:
    draw a horizontal axis
  42. Step 42:
  43. Step 43:
    use trim command for shown edges
  44. Step 44:
    your sketch have to be like this
  45. Step 45:
    make same things for the others
  46. Step 46:
    select all the inside of the cylinders
  47. Step 47:
    then select this area
  48. Step 48:
    cut the body by 70 mm
