ZWCAD Tips | Use Block Attribute to create a customized component library
Want to access your frequently used components more quickly? In addition to a library of standard parts, ZWCAD offers Block Attribute for designers and engineers to customize component blocks and create their own component libraries. This function can considerably reduce repetition and enhance your work efficiency.
Start the Tool Palette through [Tools] and click [Tool Palette Window] or use the shortcut command [Ctrl+3] on the menu bar.
Select the required component block on the current drawing, then hold down the left mouse button, drag it to the tool palette and release it. After that, the block will be added to the Tool Palette.
