How to use helical sweep cut to make threads in Pro-E\Creo ??
Ok lets get started...
Used a simple bolt....
Go to insert and select "helical sweep" -> "cut" option....
A dialog box will opens with a menu manager....
Now we will keep everything in "default" state as selected by software.See the menu manager.(you can make threads right/left handed,variable/constant pitch etc..)
Press "done".....
Nextly select a plane on which sweep profle has to be made...
or select a plane passing through the axis of the bolt....
Select "okay"....
Its looking for a reference plane..select firstly the sketch view and then the reference plane(in this i've selected plane on the fastener)....
Firstly make centre line.....
Now start sketching the length of thread(defined by length of line),depth of cut(defined by distance of line below the bolt surface)....
enter pitch value........
Make the profile of the cut to be made........
Select the side from which material is removed.......
done.........cheers
